Battery Draining Overnight
pigacab
Hello
Many T6.1 owners have reported unexpected battery drain overnight; even when the vehicle is parked with no visible power consumption. While some cases are due to standard systems like the alarm / infotainment standby mode, others suggest phantom power draw from hidden sources like aftermarket installations, faulty relays; or even VW’s factory-installed modules not entering sleep mode correctly.🙃
A common culprit could be the DC-DC charger, auxiliary battery setup, or a malfunctioning relay that keeps drawing power even when the vehicle is off. Some users have found that unplugging certain fuses or using an ammeter to test circuits helps pinpoint the issue. But the question remains—what are the most effective ways to diagnose and permanently fix battery drain in the T6.1? Could VW’s software updates or BCM resets play a role?🤔 Checked https://www.t6forum.com/threads/battery-drain-issue-resolved.38589/Minitab guide related to this and found it quite informative.
Have you encountered a similar issue with your T6.1’s electrical system? What troubleshooting steps have worked for you? Let’s discuss diagnostic methods, share insights on problematic components, and explore potential solutions.🤔
Thank you !!🙂
  • Antworten 0
  • pigacab
Aktive Tage
  • Von 51 Mitgliedern gesehen
    Schimmic Nordlicht60 Zauncamper mimo76 Multi22 pku70 PaulW derkuurt starwars magicrunman krueschan76 GerdiS gele Avante Tim_Jochen pigacab Peter55 rolthof89 Mario2u aderci nick0297jan franzfinanz GruenNdB RayP GerSchi Heizfeiz solarsolar midabu DonPellegrino Professor-Lumen p.eter tonitest donneahi redone voelligahnungslos EwaldTx Callinichda Franz T. Nero3 chruesi wunderwuzi nettemario snipy Benno_R Emmental Californiger die_braue Bertram-der-Bulli ppschmitz calimerlin Dieselschnüffler
