VW WiFi Option
Breeze
Hi has anyone chosen this option and is it working well?
Regards,
Will
  • Antworten 2
  • Breeze
  • Mat5
Yes, I did
Yes, it is working well
Yes, it is shown in the display nicely but for what reason ....
Yes, its expensive
It has an internal WIFI antenna, good for outdoor surfing ....
I dont know if there is any external antenna connected
I would not order this option again, it´s fun, it´s tech but a normal personal hot spot by phone works the same
Hi Mat,
Many thanks for your reply.
I have this option (lesswire) but believe I have an problem as I have little signal unless I am camped close to a Vodafone antenna. I carried out a speed test when I do have a signal.
When connected via WiFi I had 2.4 Mbps download, a then connected via 4G I had 18.9 Mbps. this indicated to me that there is an issue either with the antenna or the router itself.
If you have an opinion please share as I would appreciate it.
Regards,
Will
    MaJo72
