ciki62 Geschrieben 20. Oktober 2016 Teilen Geschrieben 20. Oktober 2016 Hi, I have question, for all of you who raise suspension either Seikel or VB air. Do you also have special aluminium underside protection panels? Something like this http://www.seikel.de/produkt-kategorie/volkswagen-t6-eh/?lang=eh&filter_produktkategorien=protectors thanks,. and sorry for posting in english, you can answer german, i will use google translate p.s. Kit from Seikel is more than 1200 for engine and differential. IMHO little bit too much for piece of aluminium. Zitieren Link zu diesem Kommentar
Gast Geschrieben 20. Oktober 2016 Teilen Geschrieben 20. Oktober 2016 You should take a look at the You do not have the required permissions to view the link content in this post. . The keyword ist ""... Zitieren Link zu diesem Kommentar
CaliPilot Geschrieben 20. Oktober 2016 Teilen Geschrieben 20. Oktober 2016 You do not have the required permissions to view the quote content in this post. Hi, i have the Seikel suspension but just the "widder" protection panel. I thought about the other panels but didn't bought them because i don't have plans to make extreme offroad trips. If you don't abuse your car like a rally race driver you should hear when the engine protector is touching the ground and if so, you shoud turn around ;-) We made some rough trips through Spain and never had issues, there are a lot of users from this board who made trips through Iceland and even with a 2 wheel drive without protection panels, they all made it well back home... And yeah, Seikel is pricey, i had the same impression when i looked at their pricelist - 700 bucks for a plate of aluminium. I made then a small company tour with Mr. Seikel and as i saw the panels i was impressed, they are hughe, well welded and fit perfectly under your car. I have never regretted it. Chris Zitieren Link zu diesem Kommentar
ciki62 Geschrieben 21. Oktober 2016 Autor Teilen Geschrieben 21. Oktober 2016 You do not have the required permissions to view the quote content in this post. Zitieren Link zu diesem Kommentar
